what montero/l400 parts are the same?
Posted: Thu Apr 28, 2011 8:46 pm
by Dunc
Is there a list of parts the L4oo share with the montero? I know i've seen parital lists somewhere.Specifically i'm looking for a Radiator. Front montero calipers from napa belingham are less than half 70$ what Japanoid is asking.Thanks dp
Re: what montero/l400 parts are the same?
Posted: Thu Apr 28, 2011 10:33 pm
by MEXIBISHI
Rear and front brakes asembly, and some components from the front end.
By the way, if you can't find a brand new radiator, you still can fix it, depending where is the leak located.
(On the plastic or the aluminum part) You can message me if you want more info.
Posted: Thu Apr 28, 2011 11:55 pm
Same :
Rear brake rotors, calipers and pads
Front brake calipers and pads (rotors are different)
