Inconsistent Idling
Posted: Sun Mar 02, 2008 12:06 am
by Frisch
Sometimes, after prolonged driving on WVO, my engine will idle erratically as though I were tapping the throttle every 10 seconds. Seems to not happen on Diesel.
Anyone else experience this?
Re: Inconsistent Idling
Posted: Sun Mar 02, 2008 11:36 am
by Breadman
air conditioner affects the idle speed and alternator on two battery systems seems to do that as well.
paul
Posted: Sun Mar 16, 2008 5:44 pm
by Coultrains
Hello Frish nice to see you on the site. Hows the veggie running. got a steady source on oil?
Posted: Sun Mar 23, 2008 5:45 pm
by after oil
bump
did you get this worked out? my truck does it too. when im stopped or idling, the idle seems to increase in 3 second intervals till eventually it wants to die. but it drives just fine.
Posted: Sun Mar 23, 2008 8:17 pm
by Mard
Maybe it's not getting enough fuel when idling? are you using the filter for diesel and oil? is it heated?
Posted: Mon Mar 24, 2008 9:06 am
by after oil
Mard wrote:Maybe it's not getting enough fuel when idling? are you using the filter for diesel and oil? is it heated?
if youre asking me, and not the original poster, the answer is:
the diesel is filtered by the stock filtration unit (remember, im not in a delica, yet, but a nissan) and the wvo by a heated unit. heated with a homemade thang: 1/4 coolant hose wrapped tightly around the filter, covering the whole thing quite nicely. thing is though, the idle problem happens on both diesel(or b100) and wvo. and its intermittent
i guess first thing i should do is change all filters to eliminate that from the equation...
Posted: Mon Mar 24, 2008 4:52 pm
by Adrock
Do you have any electrical heating units on board? Increased drain on battery = increased strain on alternator? Seems logical.
Posted: Mon Mar 24, 2008 9:19 pm
by BCDelica
Could be pressure change within the injection system, a very common problem with WVO systems.
Posted: Fri Mar 28, 2008 6:29 pm
by after oil
Adrock wrote:Do you have any electrical heating units on board? Increased drain on battery = increased strain on alternator? Seems logical.
there is a glow plug that helps to heat the oil, but it shuts off when engine gets warm. however im not sure how alternator is connected to idle speed.
BCDelica wrote:Could be pressure change within the injection system, a very common problem with WVO systems.
is the pressure change because of WVO in and of itself, or a change when the fuel changes? thats kind of a weird question i guess but i hope you get my drift. can it be adjusted?
