Delica Parts
Posted: Thu Feb 08, 2007 10:10 pm
by mdrive
Brand New Parts:
WATERPUMP $150. GMB JAPAN
FRONT BRAKE PADS: $35. GENERIC
REAR SHOE: $70. AFTERMARKET JAPANESE
REAR SHOE RELINED: $55. LOCAL
OIL FILTER: $20. TAIWAN
FUEL FILTER: $25. TAIWAN
AIR FILTER $25. TAIWAN
FUEL PUMP REBUILD KIT: $65. JAPAN
TENSIONERS: $40. GMB
DISC ROTOR: $65. KOREA
TIMING BELT: $42 GERMANY
TENSIONER BELT: $40 SINGAPORE
TIE ROD END OUTER: $57. TAIWAN
BALL JOINT: $55. TAIWAN
HEADLIGHT: $350.
FRONT QUARTER PANEL SHEET METAL: $30. TAIWAN
OVERHAUL HEAD GASKET FULL SET: $85. TAIWAN
BRAKE MASTER CYL KIT; $40. TAIWAN
TAIL LAMP: $40 TAIWAN
Prices are suject to change without Notice. Promotional Offer, Limited Time only.
Posted: Fri Feb 09, 2007 12:31 am
by 39Ronin
Is this new stuff or used?
Posted: Fri Feb 09, 2007 10:23 am
by surferboy
yeah, and where are those parts from, any warranty? what if the part fails after installation, who will be responsible if it caused major dammage to the engine? Thanks for any further infos as to where these parts are manufactured and by who...
Posted: Fri Feb 09, 2007 2:39 pm
by mdrive
all parts are New
most parts are from Japan. Filters are from Taiwan. Bearings are from Germany.
This is promotional price and limited time offer only.
Parts are under warrenty however, detailed will posted as soon as you identify the parts you need.
