1993 Delica Chamonix 94,000 kms ( Comply & Service) SOLD
Posted: Sun Jun 15, 2008 8:32 pm
by MardyDelica
For sale: 1993 Delica chamonix 94,000 kms
Price: $ 10,800
Amazing Auto Imports Ltd
DL # 30843
Stock # A-08293
Mardy ( Mardydelica)
T- 604-247-2111 / 604-720-6144
Did the ff service & Details of this delica:
1.) New Timing belt ( Mitsubishi 2 Pcs),new water pump Japan,2 new bearing, 4 new seal (orig mits),thermosthat.
2.) Change all fluid oil, gear oil, antifreeze 70/30 mix
3.) new transmission oil,change filter, clean transmission pan
4.) New depo headlight with 4 new osram bulb(germany)
5.) Comply & registered with day time running light
6.) 4 brand new 6ply LT tire yokohama geolander ats
7.) undercarriage has been re-grease
8.) 4 New pro-comp shock 9000 series
9.) Grade 3.5 & B, No rust
10.)New sway bar bushing upper & lower(Poly-urethane)
11.)LSD Differential
12.) 2 battery, design for Winter package
13.) Has turbo timer installed
14,) Has wood steering as you can see in the pictures
15.) Runs very good & stable
16.) 8 passenger bench seat model inside is very clean
17.) Automatic transmission
18.) will do front panel seal, inner & outer to prevent front water leak
Re: 1993 Delica Chamonix 94,000 kms ( Comply & Service) in Stock
Posted: Thu Jun 26, 2008 10:20 pm
by MardyDelica
Update: this Delica has Deposit on hold for now:
Cheers;
Amazing auto imports Ltd
Posted: Mon Jul 07, 2008 7:38 pm
by MardyDelica
This Delica is sold to a nice owner:
Thank you Erik, Hope you like it.
Cheers;
Amazing Auto imports Ltd.
