Changing Air Filter
skully
Vehicle: Mitsubishi Delica Super Exceed!!
Changing Air Filter
Post by skully »
I was wondering if anyone could help me out and point me in the direction of the air filter? :?
It needs to be replaced but not sure where to find it. And any suggestions on a good
replacement brand?
after oil
Re: Changing Air Filter
Post by after oil »
try a search, or go to the wiki from the forum page.
the airfilter is behind and under the drivers seat..
Behind the front driver wheel... It's a big can that has 2 clips (no tools required). Take off the cap and unscrew the bolt that holds your filter. One of the easiest maintenance on your Delica!
Post by Green1 »
access it from under the vehicle, immediately behind the front driver's wheel, remove the clips and the cover will come off, then you undo the wing nut and the filter itself comes out.
skully wrote:I was wondering if anyone could help me out and point me in the direction of the air filter? :?
replacement brand?
I like the WIX brand, a bit cheaper than K&N and more paper accordion-thingies inside (better filtering). WIX number 42222.
Schwa
Vehicle: 1992 Delica Exceed
Post by Schwa »
I didn't change mine for a while, but I should have checked it a lot sooner... The plastic turbine thingy was cracked and there were two washers (a new one comes with the filter) stuck to the wingnut, one of them still with the packing tape!
