L400 Alignment Specs
Posted: Fri Nov 13, 2009 1:14 am
by wetcoast
Hello, Looking for basic alignment specs.
Re: L400 Alignment Specs
Posted: Fri Nov 13, 2009 5:22 am
by Stiful
G'day.. This is from a post from an Oz member who seems to know a bit about these things. He has also made suggestions to improve tyre wear which will not help you as you drive on the right/wrong
side of the road but you wheel alignment guy should be able to translate that to be useful for your situation...
Toe = 0mm, +- 1.5mm
Camber = -0deg20min +- 30min
caster = +3deg20min +- 30min
KPI = +16deg.04min
I would suggest 1mm toe in, left camber -10min, right camber 0deg, and make caster angle of right wheel 15-20mins less than left wheel. This should give you good tyre wear and make it run straight on cambered roads.
Cheers..
Posted: Sat Nov 14, 2009 7:34 pm
by Terence Yuen
So this is why you asked on the delicaclub.com forum, Jasper.
RT from delicaclub.com has a service specification that seems to be the factory specification.
RT wrote:Delica L400 4WD Spacegear Wheel Alignment specs from May '94 onward
Toe In: 0 +- 3mm (0 mm with a tolerance of plus/minus 3mm)
Castor: +3 deg 50' +- 30' (Plus 3 degrees 50' with a tolerance of plus/minus 30')
Camber: -0 deg 20' +- 30' (Minus 0 degrees 20' with a tolerance of plus/minus 30')
The European Space Gear/L400 chassis manual states the following.
- Toe-in
- At the centre of the tread, 0 ± 3 mm
At the rim of disc wheel, 0 ± 1.7 mm
Toe-angle (per wheel), 0° ± 7'
Camber
- 2WD, 0°00' ± 30' (Difference between right and left within 30')
4WD, -0°20' ± 30' (Difference between right and left within 30')
Caster (laden)
- 2WD, 3° 27' ± 30' (Difference between right and left within 30')
4WD, 4° 06' ± 30' (Difference between right and left within 30')
Kingpin inclination
- 2WD, 15° 40'
4WD, 16° 05'
Note the slight difference in caster between the two sources.
