sunroof sliding problem?
Posted: Sun Jun 17, 2007 11:29 pm
by jimmy
hi
does anyone know what can be done to help the sunroof slide a bit easier? my one works ok but it is slower than my friends one and seems that the motor is working harder than it should. ive greased the slider and tracks but its only a bit better?
anyways, hope someone out there might have some ideas.
chow
Re: sunroof sliding problem?
Posted: Mon Jun 18, 2007 12:13 am
by ccautos
The only way to repair it properly is to drop the whole sunroof assenbly out of the van and thoroughly wash and clean all the slides . Once they are cleaned of all debris then work the roof back and forth applying liquid grease to all moving parts . I have done several up to now and it works perfectly after repair . Only down side is that it takes almost six hours to complete . Feel free to call me at the shop for any technical assistance (250)954-2157
Posted: Tue Jun 19, 2007 7:17 pm
by jimmy
thanks ccautos, that is appreciated.
im gonna tackle that this weekend and see how it goes, not being the handiest of delica owners out there im sure mine will take 12 hours! took me 4 hours to change the glow plugs~~ :shock:
wish me well!
Posted: Tue Jul 10, 2007 8:28 am
by Pajerist
ccautos wrote:liquid grease
Could you recommend any specific brand?
Thanks,
Posted: Tue Jul 10, 2007 11:20 pm
by ccautos
We use a product called HHS2000 made by Wurth from germany . It is an aerosol that sprays in a liquid that sets as grease once it has ran into all the `cracks` . The grease is good to -40degrees C and lubricates very well . Any light oil or grease will work just makes it a little easier to apply with a spray can .
Posted: Wed Jul 11, 2007 8:19 am
by Pajerist
ccautos wrote:HHS2000 made by Wurth from germany
Thanks ! How can I get it?
Posted: Wed Jul 11, 2007 7:31 pm
by ccautos
It is not sold off the shelf in a parts store . You would have to contact an area representitive directly . Not sure who it would be but lookup Wurth Canada on the internet and you will find the name and contact details for someone in your area .
Posted: Thu Jul 12, 2007 8:14 am
by Pajerist
Thanks!
Posted: Wed Jul 18, 2007 2:55 am
by DEL BiG RiG
You may also want to compare years of both yours and your friends delicas. They actually changed the motor sytem I think in 1992 (don't want to say any exact yearsfor fear of someone correcting me). When we repaired a 1991 with 1992 parts, the drive system was completly different (wire rope verus a cable). Not only were they slower, but they also made more noise.
If they endup breaking...
Check out http://www.thedelicapage.blogspot.com for a play-by-play of the replacement process. And yes, the first time does take a long time to do it. Of course after you do it once or twice, the process can become easier up. Best to either leave it to someone who has done it before or do it with a friend so you don't go crazy, or better yet a 12-pack of ice cold friends.
Posted: Wed Jul 18, 2007 10:08 am
by josh
DEL BiG RiG wrote: do it with a friend so you don't go crazy, or better yet a 12-pack of ice cold friends.
Of course a 12-pack will make your repair take on a whole different flavor. That is if it ends up getting repaired at all, or just broken a bit more severely. :-D
Josh
