New to L400's ? What to look for and/or replace on 4M40 2.8L
Posted: Sat May 01, 2010 1:07 pm
While some drive away a vehicle without thinking about it, others need to know what can fail or what mechanical things can go wrong.
You can find L400 Spacegear's for cheap to expensive. The saying goes 'you get what you pay for'. This is usually the case with JDM vehicles, although not always.
When considering/purchasing/owning an L400 Spacegear 2.8 4M40, please consider the following advice.
These are things that I consider mandatory (L400 Spacegear - 2.8L 4M40 specific) and can be devastating to the engine/L400 if left unchecked/replaced.
Prices are what I've found as average for parts only (labour is extra) -
*replacing everything below can be in the 1,000's of dollars including labor.
DIY removal/installation difficulty :
* No mechanical knowledge - no tools required
** No mechanical knowledge - minimal tools required (screwdriver/pliers,etc...)
*** Minimal mechanical knowledge - tools required (screwdriver/pliers,/wrenches/socket set/drain pan,etc...)
**** Backyard/average mechanical knowledge - tools required (screwdriver/pliers,/wrenches/socket set/air tools,etc...)
***** Expert mechanical knowledge - Major mechanical tools + specialty tools required
1. Coolant expasion bottle $130-150 ***
- It's located on the passenger side firewall in the engine compartment. It is made of non-UV resistant material and get very brittle under UV/sunlight rays. Unfortunately, sunlight hits it in between the fender / hood crack.
- If left unchecked/replaced, it can break at various points, usually at the nipples where the hoses connect. If it breaks, coolant shoots out under pressure and this can lead to complete loss of coolant in your engine = engine catastrophe.
*note : the coolant will need to be drained and replenished (see #2. water pump below).
*note : this is also a good time to change the lower/upper radiator hoses and coolant expansion bottle -> rad hose as they will wear over time (regular maintenance item).
2. Water pump & thermostat $90-200 ****
- Located on the engine behind pulleys/belts.
- If left unchecked/replaced, it can seize and/or plug up with corrosive material. This can cause coolant pressure buildup in various parts of the coolant system. End results can vary from coolant leaks to engine catastrophe.
*note : this is a good time to change the drive belts (since they are coming off) and check the coolant ports/tubes going to/from the block and turbo for any corrosion/plugging.
3. Valve cover gasket set $45 ***
- Located on top of the engine. The gasket set is comprised of 5 pieces. The main valve cover gasket, two cone-shaped rubber grommets and two (front/rear) half-moon rubber seals.
- This is a general maintenance item and if it has not been replaced recently, the likelyhood of an oil leak is high, especially around the half-moon seals.
*note : while you have the valve cover off, this would be a good time to check & replace if needed the timing chain and tensioner (see below).
4. Timing chain & tensioner $120 - 180 *****
- The chain & tensioner should be replaced every 2-400,000 km's. There is no recommended change interval, so this is a broad figure. I would estimate that 300,000km's would be the average change interval. With the valve cover off, it is simple to check the timing chain for any slack/tension. The tensioner is a simple re&re, however the timing chain requires a grinder/specialty tools and if the cam shaft/crank shaft - timing is shifted while replacing the chain, it can lead to poor operating conditions and problems down the road. Mechanic is recommended.
- If the chain is chuffing (steam engine noise coming from the engine while under load - going up a hill with foot on the gas pedal) or loose, the possibility is there for breakage which will lead to engine catastrophe.
5. Injection Pump main seal $400 - 600 *****
Problem : Hard starts, white smoke, coughing & sputtering, stalling after a few blocks, etc...
Why : injection pump main shaft seal has dried up and it allowed air/condensation to seep in causing problems above
Solution : replace the injection pump main shaft seal *note
*this is not a simple process. It requires detail and attention. If the timing marks or anything engine-timing-related is not correct, then the engine will either not run or will run very poorly. This is reserved for either a licensed mechanic or a very mechanically inclined person.
Approximate re&re = 4-6 hours (varies per service shop)
Seal cost = $15-20 (varies per parts supplier)
The rest of the seals/o-rings in the injection pump are viton (synthetic rubber - Mitsubishi replaced the old rubber one's from 1994 onwards) and are not in need of replacement unless they have been damaged. If a service shop insists on rebuilding the whole injection pump and replacing the seals, I recommend to get a 2nd opinion unless the original diagnostic is done by a reputable service shop.
6. Engine/Transmission/Transfercase/Differential fluids and filters - re&re $cost of fluid + labor *** to ****
- This is the nutrients your engine and drivetrain require to function properly. If left unchecked, can cause serious damage to minor and major parts of the driveline. Dirty filters can cause problems down the road.
*Not to be ignored.
7. Glow plugs & wiring $20-60 ea (four in total + wiring)
- essential part of starting operation.
- wiring/bus bar are prone to corrosion. Replace if required.
8. Suspension (these components are all tied together and often if one needs to be replaced, so do the others) :
a. Front control arm bushings $50-70 ea (four in total) ****
- Knocking sound coming from the front end and loose/vibrating wheel.
** Wheel alignment required.
*this is very common on IFS system like the L400. Replace as necessary. Testing is simple. Both wheels off the ground safely, turn the wheel until full lock with force. Person observing the control arms will see if they move or not. If they move, replacement is required. Removing them is only with a torch or specialty press.
b. Front sway bar linkages $40-70 ea (two in total) ****
*common as well and replace as necessary. When unbolted and free, it should be tight and not loose (jiggly).
c. Tie rods (inner/outer) $30-70 ea (two each = four in total) ****
- Knocking/clicking sound coming from the front end and loose/vibrating wheel.
d. Upper/lower balljoints $40-140 ea (two per side = four in total) *****
- Knocking/clicking/squeaking sound coming from the front end and loose/vibrating wheel.
* I will update this thread on a regular basis with new information.
*Not to be ignored.
