Hi All,
As the subject indicates, this is a total noob question, but I can't figure out how to put my L400 into 4-low. I had it at a full stop and in neutral, with it in 4Hlc, but couldn't get the lever to move in any direction. How do you move the lever to put it in 4-low?
Thanks,
Colin
Noob question about 4-Low
- Vehicle: 1994 Delica L400 Exceed HR SWB
- Mr. Flibble
Re: Noob question about 4-Low
From 4-Hi, and if you are in Neutral, push forward on the lever with an ever so slight rightward lean, but it is mostly forward, and a long way forward at that.
Thanks a lot! I'll give it a try today.
I tried again today, but I still can't get the van into 4 low. I get it into 4hlc, but the lever won't budge past that I have it in neutral when trying. There's no line connecting 4hlc with 4llc on the shifter knob, so i'm actually wondering if it has 4 low at all. Do all Delicas have 4 low?
Thanks,
Colin
Thanks,
Colin
- tonydca
Push down on the shift lever, then to the right and forward.
- Mr. Flibble
Oh, yes! tonydca is correct, you need to push down on the top of the stick to shift as well. I totally forgot that. I always push down on the top now out of habit. I actually need to engage 4X4 very often as my driveway has a 20% grade in one spot.
Thanks everyone! Took it out on a logging road today and gave it a whirl, popped right into 4-low!
