Lock-up torque converter?
loki
Post by loki »
Anyone know if there is a lock-up torque converter that will go in the deli auto trans? I think it would help the transmission live a bit longer and should provide a little better fuel economy, I think.
Schwa
Vehicle: 1992 Delica Exceed
Re: Lock-up torque converter?
Post by Schwa »
I'm pretty certain mine locks up, although I haven't checked to see if it is for sure, it definitely has a phantom 5th gear.
loki
Post by loki »
Schwa wrote:I'm pretty certain mine locks up, although I haven't checked to see if it is for sure, it definitely has a phantom 5th gear.
Well it really should lock up in any gear once the tranny starts to get close to the same speed as the engine, this eliminates lost power and helps keep the tranny cooler especially when towing or climbing. Unless I'm totally of my rocker here.
docsavage
Vehicle: Deliless...
Post by docsavage »
The manual for the auto box on the Wiki shows that there is a lockup clutch available on the transmission model for that manual. Check which tranny you have, if it is in the manual, it may have a lock up, or one may be available.
James
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
loki
Post by loki »
docsavage wrote:The manual for the auto box on the Wiki shows that there is a lockup clutch available on the transmission model for that manual. Check which tranny you have, if it is in the manual, it may have a lock up, or one may be available.
James
cool thanks.
