Cleaned injectors now won't start :( :(
- Vehicle: 93 Delica
Took out my fuel injectors to clean them up with "carb & choke cleaner" figuring that a little cleaning would at least improve the running and starting condition a little while I wait for new ones to arrive.... well after reinstalling them the Delica won't start :( :( Tried cracking the line to the injectors to let the fuel seep out and also pumped the fuel filter with the return line off..... so not sure if the injectors are done or whether there is still air in the system??? I would appreciate any feedback, thanks!
- Firesong
You need someone in the van cranking it over as you bleed the injectors. Odds are its air in system.
