I was just browsing the forum, trying to figure out how to rig an AT Temp gauge without taking up too much room as I will (FINALLY) be installing my Glow-Shift Gauge. I was at a loss for how to fit one more gauge in there (I am using a RHD pillar pod, it will contain 5 readouts) and I stumbled across your suggestion.RichD wrote:Question for the forum: what would you use the temperature gauge for: engine oil, water or trans oil temp?
It occurred to me that I could order two more temperature sender probes and put them on a three-way two-pole switch.
It is brilliant! It is exactly what I will be doing. Lets me monitor coolant or AT at the flick of a switch! Now maybe to figure out something with an indicator to show which is which: AT or Water.
