Hi All.
Can't locate the manual for my Delica. Can someone pls suggest a way of determining type/amount of differential oil I need for both front and back diff.
Thanks,
Denis
Differential Oil for DELICA 1998 V6 3000 Gasoline
- Vehicle: Delica
Re: Differential Oil for DELICA 1998 V6 3000 Gasoline
Denis
Best not lose that manual, you'll need it. Mine is in Japanese, yuch...
Crawl underneath and look for a tag on the back side of your differential. It says LSD. No tag= standard diff= 80-90 wt. filled till it flows out the fill port. Same for the front diff. Mitsu rec change at 40k kms, in your dreams....
Pretty simple stuff. DIY backyard special. Look for metal in the drain plug when draining the oil. You might need a pump for the front diff, you'll know when you look at it.
good luck
TLWF
good luck
TLWF
- Vehicle: Delica
