Propane Injection
loki
Re: Propane Injection
Post by loki »
how about switching the dino diesel out for propane in a wvo setup? or is that ludicrous?
Jester
Vehicle: Delica
Post by Jester »
loki wrote:how about switching the dino diesel out for propane in a wvo setup? or is that ludicrous?
I'm not 100% but I think that would require an ignition source(spark plugs), since I don't think propane would ignite from compression alone (unlike Diesel)
loki
Post by loki »
I also realized thinking about it later that the lines and injector pump wouldn't get cleaned out in that setup.
Schwa
Vehicle: 1992 Delica Exceed
Post by Schwa »
I don't know about LPG, but a natural gas diesel engine usually uses a tiny amount of diesel (idle, or less) injected in as the ignition source and the amount of methane controls the power.
A good setup would be to run BioDiesel + WVO, or if you can get ahold of that bio-diesel that's refined similarly to dino-diesel, then you're laughing.
Return to “WVO and Biodiesel”
