The airlift bags I have (had) are Airlift part number 61792.Krazyistkarl wrote:Anyone got a brand or part number for bags in the back? I'd like a two inch lift on the van, and I'd like bags as I'm going to have an enduro on the hitch for most of the summer so there's an extra 300lbs alone.
Part numbers and source for hd torsion bars?
What else do I need to do to the front for a 2 inch lift?
HD torsion bars you have to order from overseas, just re-index the front t bars and that will give you the lift you need. Some people have balljoint spacers on the upper control arm, some do not. When you lift though, just make sure you either put a 2" spacer under the rear brake bias valve, or readjust it. I think Big-Bird did a write up on how to adjust it. Also, I believe Rocky Mountain Imports have rear sway bar end links that are longer than stock, so you can use them instead of spacing the rear end link mounting points.
