Murphy's law
Murphy's law
Bit the bullet and spent $4k to rebuild the transmission, because everything else is working great.
2 weeks later... coolant mysteriously vanishes from the radiator and reservoir. It's not leaking from anywhere obvious. It's not in the oil either, but surely that's only a matter of time.
I suspect a new Hyundai D4BF/4D56 engine is in my future...
north54
Vehicle: 1989 P35W
Murphy's law
Post by north54 »
Dislike! I figure with all the help you've given the users of this forum (myself included) Karma would be better to you. Good luck.
TRUSTY RUSTY
Murphy's law
Karma's good, but it's no match for time. It's just an old engine. Though the 22psi of boost probably doesn't help ;-))
lrp374
Vehicle: 91 Super Exceed
Murphy's law
Post by lrp374 »
Is this your next way to up your HP rather than fix what you've got? Some people think the Hyundai puts out more power and torque.
Murphy's law
Maaaybe ;-) The D4BF is based on the last of the IDI Mitsubishi engines with flush valves and smoother pistons (for controlled ignition at higher boost/more aggressive advance) and a water-cooled turbo. It's designed to suit an electronically-controlled injection pump for more power, but on cheaper models they just fitted the old mechanical pump anyway.
My existing engine is a pain to rebuild. Turbo engines have different pistons to Normally Aspirated engines, but aftermarket piston sets are all N/A style so you have to use genuine Mitsubishi if you want it reliable. The crankshaft is nitrided, and re-nitriding after grinding is a pain. My engine does have a new head, but it's a protruding-valve style. I'd probably have to re-sleeve the block too... I'm looking at $4k for a rebuild, or $6k for a brand new Hyundai engine- which comes with new injectors, injection pump, alternator, turbo- the lot.
Lapprentis
Murphy's law
Post by Lapprentis »
That is bad.... :?
Another Quebec member here (Fleury) did have problems whit his engine a while ago: he was facing the same dilemma ($$$) as you. He chooses the brand new D4BF and never regret it :-D I wish my engine is healty for a loooooong while but the choice for me would be easy: keep my Van and add a brand new engine ! Can't you find second hand 4D56 in NZ ?
Keep in touch 8-)
Lapprentis :M
lrp374
Murphy's law
Post by lrp374 »
So what would happen to that fancy new turbo you installed a while ago?? :?
Morgonzo
Vehicle: L300
Murphy's law
Post by Morgonzo »
Damn GB, it looks like you're only left with expensive options. I wonder if we Yanks would have the option of a NEW D4BF. I doubt it the way the States keep us away from new Diesel tech not brought to market by Ford or GM (and not even Ford sometimes as in the case of the new Ranger..). In the meantime your Delica-less right? is that your only ride? Have done anymore investigating as to where the coolant went?
"Zowie Zow!" :-D
Murphy's law
Lapprentis wrote:Can't you find second hand 4D56 in NZ ?
Oh yes, there's plenty, but they all have more than 250,000km. If I'm going to the trouble of fitting another engine I want everything to be fresh, and the difference in price between a rebuild and a new one isn't completely ridiculous.
lrp374 wrote:So what would happen to that fancy new turbo you installed a while ago??
Depends what's wrong with the old engine. If the leak turns out to be just a head gasket I'd probably fix it and sell the whole thing, but if it's a cracked head or block I'd sell parts individually. Why? Do you know someone who wants an awesome turbo? ;-)
Morgonzo wrote:I wonder if we Yanks would have the option of a NEW D4BF
Maybe, you just need to find a friendly importer. These guys sell them http://www.hyundaiengine.com/ but only to distributors, not to individuals. I've read that MaxOverdrive.ca used to import them, so you might get away with a short drive (hah!) over the border?
Morgonzo wrote:In the meantime your Delica-less right?
Nah. I've topped the coolant up and I'll keep driving it (while obsessively staring at the temperature gauge). Eventually it'll become obvious where the coolant is going, and even if the engine explodes I'll be no worse off.
Lapprentis
Murphy's law
Why not import (yourself ?) another Delica from Japan ? No much more espensive than a brand new engine !
Just trying to find a whay to keep you with us up yo the end of the world :o I would not consider myself not having an L300 anymore :shock: Hope you are as I am about your Van too 8-)
Lapprentis :M
204explorer
Vehicle: l400
Murphy's law
Post by 204explorer »
I was not aware that Hyundai made a equivalent engine for the L300. Does it just bolt in? I wonder if they have a equivalent engine for the 4M40. I work for a Hyundai heavy equipment dealer. You got me thinking.
Murphy's law
Lapprentis wrote:Why not import (yourself ?) another Delica from Japan ?
The most relevant reason is that they're not legal to import into NZ any more, as they don't meet emissions or frontal impact requirements.
But the real reason is that my Delica has a lot of work in it and it's almost perfect (for me): 120l fuel tanks, LSD rear/locking front differentials, spare tyre carrier, intercooler, rebuilt transmission... it really is just the engine that's letting me down now. I can buy a second-hand engine locally quite easily, but if I'm going to the trouble of pulling the old engine out I want to put something guaranteed reliable back in- and that means new or rebuilt, which means $$$ either way.
204explorer wrote:Does it just bolt in?
Allegedly- almost. The oil pan will need to be swapped for the Delica one, and possibly the oil filter bracket. Flywheel/clutch will be swapped for my existing flexplate. The water pump outlet is on a different angle so the lower coolant pipe will need some fudging.
I don't think they make a 4M40. Check out the link to the engine distributor above.
thelazygreenfox
Murphy's law
Post by thelazygreenfox »
GB Well if anyone can do it you can. Sorry to hear about your misfortune. :-(
MD
Murphy's law
Growlerbearnz wrote:The most relevant reason is that they're not legal to import into NZ any more, as they don't meet emissions or frontal impact requirements.
Not legal to import or not legal to insure?
Murphy's law
FalcoColumbarius wrote:Not legal to import or not legal to insure?
Not legal to import (except as spare parts, but that's a nightmare to negotiate). We don't really care about insurance here, it's not a legal requirement.
