After some inspection, I found that while the belt was tight, my mounting bolt was just... gone!
1: I'd marked the adjustment bolt before removing so I could get close to the original tension, but with the new alternator the adjustment bolt is pretty much bottoming out. again, belts were tight when I remove the old one and as far as I can tell the bolt locations are identical.
2: I have decent tension on the belt, but I'm still only getting mid-12 to low 13 volts to the battery with nothing running, so is there some other reason a brand new alternator might not be charing the battery?
Any advice here would be appreciated!
