Hey,
so i checked the wiki and i didn't find any info for brake lines. I need to replace my front brake lines, the rubber is looking brittle and has started to weep in one spot... so before i kill myself or someone else i had better just replace all of it.
looking for part numbers and where people have bought the parts.
thanks for any help
martin
front brake line?
- windsnob54
- Vehicle: 92 exceed
front brake line?
92 Passat Syncro wagon 1.9td
92 Delica Exceed
92 Delica Exceed
Re: front brake line?
Go to any parts shop
Mitsubishi Montero 1982 - 1989
Part #'s should be identical.
If not, then anyone of the local importers should be able to get them for you (vendor section).
Jesse
Jesse
- mdrive
MR129771 & MR129744
I don't think it matches with Montero. You can contact us if you need them now. We have 2 in stock.
- loki
both are the same as an 86 montero or dodge raider at the very least. Lordco in Victoria has them on their delica parts list now.
