Aha! I get you - I thought you were saying the towing point wasn't fine because there was a hole near it!Green1 wrote:The tow point is fine. the problem on my vehicle is that someone ignored the perfectly good tow point and hooked in to a hole on the frame rail instead, these are NOT strong enough and obviously tore out.
All makes sense now! Why someone would want to use a hole in the chassis rail to tow/pull something is way beyond me??
Thanks for clearing that up....
