Then, with a little rag action the problem became apparent...
And, that's not the only lobe damaged. At least six of the eight are in a similar condition.
Guess I need a new cam. Do any of you have suggestions on suppliers?
It's a rubber gasket. Replacing it is a good idea if it hasn't been done in a while, but I would expect that you could have a peek without problems. Not sure if you should replace it everytime you want to check your valve clearances. However, I would bow to the ones with greater knowledge here (ie. real mechanics).snelson wrote:Hey guys,
By digging in to look at the cam do you need to replace your valve cover gaskets? Or can the cover be opened and the gasket reused?
Steve
