HITCH FOR DELICA
Re: HITCH FOR DELICA
dfnder,
Taiwan would be my guess...
yamano4x4
Vehicle: delica L300
Post by yamano4x4 »
DELICA L300 3hole TOWBAR aboriginal create
delicat wrote:dfnder,
CMC - "China Motor Corporation," in Taiwan. The following is from wikipedia entry:
13.97 percent of the company is owned by Mitsubishi, and all of their models are revamped Mitsubishi designs, adjusted to appeal for the Taiwanese market except for Freeca and Veryca, which are entirely CMC designs and not based on Mitsubishi models.
intlfunk
Post by intlfunk »
I'm definitely in! Once the mod is done, pls let us know and I'll put in an order. Hoping to do the install myself (don't really have tools for cutting thru metal).
Um, do the brakes need to be upgraded if pulling over 1700?
intlfunk,
The cutting mod is only required if you have a sway bar at the back. If you don't theen you're fine just as it is. If you have one just mark where you want it cut and bring it to a muffler shop with a beer, they'll have it faster than they can drink the beer...
And if you want one I'd probably contact MaxO/D directly just in case he doesn't notice your reply...
David
intlfunk wrote:I'm definitely in! Once the mod is done, pls let us know and I'll put in an order. Hoping to do the install myself (don't really have tools for cutting thru metal).
The "1700" you are asking about is kilograms, and I wouldn't want to pull that much in these - at least not up and down hills. Remember, it's only an 85hp engine, so it will only be able to handle so much. This is from my post about driving to Calgary and back with a little utility trailer and a full van:
The Number 3 highway is a wonderful road, through some of Canada's most varied terrain: a huge river delta, lush orchards, a desert (Canada's only), semi-desert, a mountain range and another and another and another, high mountain meadows, etc. Only thing not on the Number 3 is arctic and tropical!
Did I mention mountains? There are four mountain ranges between the ocean and Calgary: the Coast Mountains, the Columbias, the Cascades, and the Canadian Rockies - that's a lot of up and down. Worst of it is, the Number 3 is the steepest of it! Kootenay Pass was nearly the end of it at 1774m, but I managed to keep the rpms and speed down such that the temperature needle was just shy of the red. Of course, two adults, four children, two dogs and a utility trailer with all sorts of stuff in it didn't help, but at least we didn't take the tent trailer (I think Moon Machine would have boiled over for sure). Still, we made it and that was the part of the road I was most worried about.
nishby
Vehicle: '92 Super Exceed
Post by nishby »
Can anyone tell me if the MaxOD hitch takes a 2" or a 1 1/4" receiver?
TardisDeli
Post by TardisDeli »
2
Christine
nishby
Post by nishby »
Geez Christine, I think you know everything!
Charmin or White Swan? :-D
Thanks.
everythingells
Vehicle: Mitsubishi Delica L300
Post by everythingells »
i just purchased one of these hitches and its great!!! affordable and mounts really easy. i have been towing a utility trailer and snowmobile. no problems at all.
Purex.
everythingells
these are great hitches. i just ordered one in December and have been using it since. i was just 4X4 ing on a sled road and got stuck pretty bad. used the hitch bar to rig my ratchet/tow rope to a tree and pulled it out. no movement at all on the hitch mounts. you also have options on how far the mount retreats out of or into the back of van. there are about 5 x 1" apart holes. i dont think you can adjust the clearance though. that is fixed.
i have towed my utility trailer with a snowmobile (900 lbs) and dint even feel the load or have any problems. the 2" receiver allows an additional (200-500 lbs) of weight on the hitch. so thats better than a 1.5" reciever.
jcolvin
Post by jcolvin »
Just installed my MaxOD hitch, and it's great. Went in fairly easy, no modification required (didn't have to grind anything). Included all the mounting hardware required EXCEPT the 2 long bolts that go all the way through the frame for the top-most mounting location. Also the hitch has to be mounted in the rear-most position possible or the spare tire won't fit. This reduces the mounting strength somewhat as it means that the two mounting bolts are close together and the hitch won't be able to take as much tongue weight as it would otherwise. But for my purposes (towing a light zodiac on a trailer) it will work just fine. oh....and the hitch doesn't include the ball mount (at least, mine didn't). Perhaps it did in 2008, but not any more....
dreamer
Vehicle: L300
Post by dreamer »
Hi everyone,
Just out of curiosity, do other hitch systems work for the Delica? It seems as though the one on offer from Max Overdrive is specially designed for Delicas, but how do other, perhaps more standard hitch systems fare? Any input would be much appreciated,
Ryan
mdrive
Post by mdrive »
We have Hitch for Delica L300 and L400 in stock now. We could not sell many customers last month due to low stock. We have now plenty of stock now.
