Hi,
We've had wet passenger foot wells ... at first thought it was bad seals letting in rain, as described here at length. But then I noticed after drying out that the darn thing was wet again, despite no rain. Wondering if the a/c (which we've been blasting the heck out of lately) could be the culprit, after noticing that a good bit of the system sits right underneath that spot.
Thanks for any help,
-- Joel
a/c + condensation = wet passenger foot well?
- Vehicle: 92 Delica Exceed
Re: a/c + condensation = wet passenger foot well?
Look for the drain for the evaporator. It might be disconnected or plugged.
some people have reported the wet footwells being caused by the A/C, as was mentioned already, check that the drain hose isn't blocked, and is connected where it's supposed to be.
Great, thanks. Sometimes search is only as good as your vocabulary.Green1 wrote:some people have reported the wet footwells being caused by the A/C, as was mentioned already, check that the drain hose isn't blocked, and is connected where it's supposed to be.
I'll go take a look - Is that drain hose hard to find?
== Joel
jskrepnek wrote:Great, thanks. Sometimes search is only as good as your vocabulary.Green1 wrote:some people have reported the wet footwells being caused by the A/C, as was mentioned already, check that the drain hose isn't blocked, and is connected where it's supposed to be.
== Joel
I wish every problem was so simple to solve :). Just like you said, the drain hose wasn't connected. Glad to know that it's there now!
Thanks,
-- Joel
- loki
please post up some pics so the next person will have an easier time locating the hose :) Pass the karma please :)jskrepnek wrote:jskrepnek wrote:Great, thanks. Sometimes search is only as good as your vocabulary.Green1 wrote:some people have reported the wet footwells being caused by the A/C, as was mentioned already, check that the drain hose isn't blocked, and is connected where it's supposed to be.
== Joel
Thanks,
-- Joel
