We found the Delica camper that we were searching for and are looking to put this one into a good home.
We never had plans to sell it, hence all of the work that's been put into it (a lot !).
Here's the list :
1992 Delica Chamonix Edition (Metallica Black on Silver)
Automatic / 2.5L Diesel (151,000km)
Winter Package (Dual batteries/glow plug system/Limited Slip rear differential/radiator guard/rear aluminum ladder)
Seats 7 + one jump seat.
Reversible middle bench seat (faces front or rear)
Rear shoulder belt restraints.
No rust on the roof & Undercarriage.
One original owner in Japan.
Delica was never smoked in.
Hypoallergenic detergents used to clean inside.
Hot/Cold Fridge Box
A/C Front/Rear
Imported and registered in BC. Government inspected (documents with Delica)
Aircared for 2 years. Passed with flying colours.
All compliance work completed in BC .
Daytime running lights, side reflectors, bulbs, headlights, etc... replaced.
Mechanical :
Timing, top end redone at 125k
New fuel/oil/transmission filters and fluids replaced less than 2 months ago.
Differential fluids flushed and filled (rear limited slip carrier).
Injectors sonic-cleaned and seals replaced.
Valve cover gasket replaced.
Newly rebuilt injection pump (complete overhaul and manufacturer spec tested)
No fuel/oil leaks anywhere on the Delica.
Dual batteries (AC Delco)
Front wheel bearings & seals replaced
Complete brake overhaul with twin-piston upgrade on the front (94+ Delica)
- Raybestos Professional Grade brake hardware used / cermanic PG pads
Custom :
Custom Lift (2.5" ride height gain over stock)
Sway bar bushings replaced
New pro comp hydraulic shocks (proper stroke length for lift kit) with 2" adapter plate
Springs re-arched and torsion bars re-indexed (firm ride)
31x10.5x15 ProComp All Terrain tires mounted on 15x8 aluminum rims (still have nipples on the tires)
Superwinch manual locking hubs on front wheels
Front Panels prepped and sealed to prevent 'wet floor syndrome'
Custom 2.5" Stainless steel side exhaust
9' Freedom II vinyl Awning (Carefree of Colorado) heavy duty awning/self-supporting
If you price out all of the work that has been done to it in the last few months, then you know the buyer is getting a bargain.
With regular maintenance (oil changes,filters,etc..) this Delica will last a very long time.
This Delica needs nothing. It is mechanically sound, clean and drives great.
Will upload more pictures soon.
SOLD
Email : jfarsang@gmail.com or call Jesse/Maryna at 778-549-4542
