As with all vehicles there are common faults with L400's.
Stuff like drop links wear on them quite quickly as do ball joints, track rod ends and front and rear ARB bushes.
They are also quite prone to the rear exhaust pipe rotting.
Always listen closely to the engine under load i.e on a long climb if you can, to see if you can hear the Deli chuff if its there it means the timing chain is worn.
They have a bit of an issue with fuel pump seals as well.
But they do have a lot more room inside than the 300 and they are easier to move around inside on account of the fact that there is no hump between the front and rear and then of course you can fold the rear most seats up against the sides of the vehicle so that you have a good load space.
If I can think of anything else I'll add it later or just have a look here http://www.mdocuk.co.uk
L400 SpaceGear
- Drooper
- Vehicle: Mitsubishi Delica L400 and Pajero
Re: L400 SpaceGear
WHITE L400 EXCEED HIGH ROOF 7 seater
Now back on the road
Its all about the game.............
.........and how you play it!!!!
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
