replacing bus bar
loki
replacing bus bar
Post by loki »
anyone know what gauge wire I should use to replace my bus bar? I'm having issues starting and I'm not confident that the plugs have a good connection and I think replacing the bar with wires for each will help with that. correct me if I'm wrong, wouldn't be the first time :)
Golf Cart
Vehicle: 1992 Exceed
Re: replacing bus bar
Post by Golf Cart »
It should be at least the same as the power wire going to the bar. 10 or 12 gauge should be the one. Also if you are making a harness for the plugs you might want to consider using the U shaped connectors. I'm forever dropping those damn lil nuts off the plugs into the engine bay never to be seen again when hooking up the wires. Then again , the Deli's glow plugs are not horizontal like on Jetta's with 2 of the buggers being behind the IP.
Good Luck
