Wanted...parts list for WVO set up.
jaydog
- Vehicle: 92 delica L300
Any body out there willing to help out. I want to set up with WVO but not sure what else I need. I have a heat exchanger with electric switch, some hose and inline filter. Making plans for a tank set up. Mostly need info on prefiltering and intank heating. Appreciate any helpful info...
- Luna-Sea
Re: Wanted...parts list for WVO set up.
Hey,
Search around the WVO section,you should find enough to get you slippery.
There are a few good install post withs lots of pics and some good
filtering set-up as well,more than one way to grease a cat.
The Plantdrive.ca site is pretty good too.
Right on!
Right on!
- after oil
http://www.journeytoforever.org/biodiesel_svo.html
and check to posts of conversion here on the forum
the list is long, and every one is different...
- after oil
btw if you live on the coast, you will probably be okay w/o tank heating.
you can edit your profile information so it says where you live over there on the left of the screen with your username etc...
AndrewH
- Vehicle: toyota surf TD
http://www.delica.ca/forum/deli-wvo-kit ... -3214.htmljaydog wrote:Any body out there willing to help out. I want to set up with WVO but not sure what else I need. I have a heat exchanger with electric switch, some hose and inline filter. Making plans for a tank set up. Mostly need info on prefiltering and intank heating. Appreciate any helpful info...
