Lights
MrDuncon
Vehicle: '95 L300
Lights
Post by MrDuncon »
Hi, I have a simple question:
Which one is the parking-light and which one is the turn signal?
The reason of my question is that i have an European version of Deli and i know it's different than japan ver.
Now these are my lights:
1: Sidelight
2: Indicator
3: Low beam
4: Main Beam and Sidelight
5: Indicator
6: Indicator
Please someone give my the answer :D
Sorry for my English
Photo blog: zoltansz.tumblr.com
Blog: jdmjinsei.com
Re: Lights
  • 1/ Indicator (side)
    2/ Indicator/flood light (side)
    3/ Low Beam headlamp
    4/ High Beam headlamp (with city light, if you have it hooked up)
The next two are differently configured than the ones in Canada, but here's a guess:
  • 5/ Running light or forward marker
    6/ Indicator (forward)
A & B: See 1 & 2.
MrDuncon
Vehicle: '95 L300
Re: Lights
Post by MrDuncon »
thank ya! 8-)
Blog: jdmjinsei.com
Erebus
Vehicle: 1992 Super Exceed
Re: Lights
Post by Erebus »
I have to disagree with Falco slightly. His answer tells me that his Delica is wired in the usual BC fashion.
Mine was unmodified from the Japanese when I got it, so stock is:
1= turn signal repeater
2= cornering light
3= low beam
4= high beam. (and city light on some models)
The japanese ones have no side marker lights. Canada requires them, so there are 3 choices: a) add a light, b) re-wire the white cornering light into an amber side marker, or c) re-wire the turn signal repeater to be both side marker and turn signal. 'C' is what I did, and is my preferred option, and is the easiest (instruction here on the forum).
5 & 6 are very different from ours. In approximately that location we have a white marker light beside an amber turn signal, but they do not wrap around to the side, they face forward only.
