L400 Spacegear2.8 radiator brand new $250 *SALE*
- MardyDelica
Hi, now offering brand new L400 delica spacegear 2.8 liter 4m40 engine Radiator bigger than original so more cooling to your L400.
has a 6 month warranty on it.
Limited Quantities= only 20Pcs for this Price
on Sale now for $195 when you buy min of 6
$215 for under 6
Cost is C$300
any question pls call me:604-247-2111 / 604-720-6144
thank you;
$215 for under 6
Cost is C$300
thank you;
- MardyDelica
Re: L400 Spacegear radiator brand new $ 300 in Stock
Now this delica L400 SPACEGEAR radiator is availble.
pls call for details.
thanks
thanks
- MardyDelica
hi, Just updating. L400 radiator in stock for now.
pls call me if need one.
Cheers:
Cheers:
- Drumster
- Vehicle: '94 L400 diesel
Hi Mardy. With the oversized radiator, how much is coolant capacity increased compared to stock?
Thanks.
Thanks.
I'm here to learn.
- MardyDelica
hi, its nearly 8 mm.
thats all i can get for bigger one. its a direct fit for your spacegear. no modification plug & play.
Cheers;
Cheers;
- Drumster
I see, but what about the coolant capacity? A stock system holds pretty much 11 litres. How much more coolant will one of these larger units need? Also, are these Mitsubishi or where are they made?MardyDelica wrote:hi, its nearly 8 mm.
Cheers;
Thanks.
I'm here to learn.
- MardyDelica
hi, it hold more coolant than original.
this is made in asia. not japan, original is more money.but this radiator is good quality.
either china or taiwan made.everything is made in asia now as per labor is cheaper than in japan.
Cheers;
Cheers;
- ccautos
- Vehicle: 92 Delica SE
I think to cut this short - yes its made in China !!!MardyDelica wrote: this is made in asia. not japan, original is more money.but this radiator is good quality.
Cheers;
But Asia sounds better !!!!
There is nothing wrong with most of the Chinese produced parts, in fact I just bought an all aluminium radiator for my Skyline and its made better than anything you can buy in N/A. We have had some fitment issues with `Asian` produced parts but check them thoroughly before installation and it won`t be an issue.
- sasquatch-hunter
- Vehicle: 2 Delica
As long as they were not made in North Korea, that's fine.
- MardyDelica
Re: L400 Spacegear radiator brand new $ 300 in Stock now
Update:
Have this delica L400 Radiator in stock: this has a bigger core & produce more cooler than original one:
tested locally without any problem.
pls call me if need one of this Radiator :
thanks;
thanks;
- MardyDelica
Re: L400 Spacegear2.8 radiator brand new
Update: This sale is only up to next month
we are expecting new shipment of Delica L400 Radiator bigger than the original one:
the price is pretty reasonable as the supplier give us a good price for limited stock only pls:
we only have 20Pcs for sale on this price: just a promotion by my supplier:
$195 for min. of 6, $ 210 for less than 6
this is well tested & i already used it to most of my Delica L400.
the regular price on this is $ 300 each.
its brand new & aluminum one like the original:
call me pls if you need one:
Cheers;
Cheers;
- MardyDelica
hi, This L400 radiator will arrived next week;
pls call me if you need it:
Cheers;
Cheers;
- MardyDelica
- MardyDelica
Re: L400 Spacegear2.8 radiator brand new $250 *Sale*
L400 Radiator on sale for $ 250 each
good until Nov 15, 2010
Cheers;
Cheers;
- MardyDelica
Re: L400 Spacegear2.8 radiator brand new $250 *SALE*
Have still few in stock,
this is brand new not used
price $250.00
Cheers;
price $250.00
Cheers;
