I'll agree slightly with the less wear. But given that in 2H there is no strain on the u-joints, diff., etc., the wear will be minimal. The likelyhood of the front parts needing service from just turning is negligible compared to the need from doing off-roading in nasty conditions.Manitoba deli wrote:Less parts turning=less wear=less fuel consumed. {snip} I would still like to put manual hubs on my l400, if I can save 1/2mpg, its worth it.
I doubt there is a measurable reduction in fuel consumption. If the parts are properly lubricated, there won't be a lot of drag. Therefore little improvement possible.
The downside of putting manual hubs on the L400 is that you will have to stop and lock up the hubs before you can use the AWD mode. The scenario I'm thinking of is driving highway in overcast, then run into a major thunderstorm. Perfect scenario for switching to AWD, but you have to stop and in pouring rain lock the hubs. Yuck.
Just my 2 cents worth.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
