HELP REPLACING HEADLIGHT BULB ON L300
netalwins
Vehicle: 1994 delica starwagon
Post by netalwins »
Any instructions or links to how to access the bulb to replace it would be appreciated. From what I can see there is no way to access the bulbs from inside the van. So I am assuming that one unscrews the headlight cover to access the bulb.
I just thought I would ask before I experiment as my right bulb is burnt out.
thanks
Aloha Al:)
Stewart
Vehicle: '90 Star Wagon
Re: HELP REPLACING HEADLIGHT BULB ON L300
Post by Stewart »
You need a 10mm socket and extension as well as a phillips screwdriver. You also need very strong fingers to turn the plastic screw-on cover behind the bulb. I think they're H1 bulbs, you might want to check that. Good luck, they're a bit of a pain to change.
Regards
Stewart
Post by Green1 »
you have to remove the corner light pod, and the headlight assembly, and then there's a door on the back of the light pod to change the bulb, a pain, but certainly do-able.
bulbs are H1 high beam and H3 low beam
snelson
Vehicle: 92 Delica Exceed
Post by snelson »
