Hi all
I had a flat yesterday and I've trying to find a sticker with the recommended tire pressure but I can't seem to find it... I wonder if it's missing from my van or maybe it's one of the Japanese stickers.
Where is this information supposed to be on a Super Exceed (Auto)?
Thx...
Recommended tire pressure sticker?
Re: Recommended tire pressure sticker?
i think its in the drivers side door frame right around where the seatbelt rests... but it is in japanese.
- Jungle Jon
- Vehicle: Toyota Tacoma
Mine says 2.0 bar, which is about 29 psi.
29psi? those would be pretty flat tires...
best bet if you can't find a recommendation on the vehicle is to look at the side wall of the tires, and take max pressure -10%
then adjust to suit what feels right.
- Erebus
- Vehicle: 1992 Super Exceed
Elsewhere in the FAQ viewtopic.php?f=16&t=917 the door post sticker is 2.0 kg/cm2, which is indeed 29 psi. Bar and kg/cm2 seems to be the same. That does indeed seem low. I like Green1's suggestion of tire's max -10%Jungle Jon wrote:Mine says 2.0 bar, which is about 29 psi.
checked my door post and it does indeed say 2.0 kg/cm3, so if that's 29psi then i don't like their recommendation...
my tires are at 34psi right now, and I get comments from people asking if I know my tires are a bit low... I'm thinking of going higher pressure....
