manual locking hubs
Re: manual locking hubs
if the brakes are a little soft you might want to check the brake fluid...
- sean
- Vehicle: WVO '91 Super Exceed
First thing I did when I noticed that and it was full..Maybe a something was affected when I replaced the pads. I will keep an eye on it (or should I say, a foot on it)
"I find television very educating. Every time somebody turns on the set,I go into the other room and read a book."
Groucho Marx
Groucho Marx
- Vehicle: Deliless...
You may have an air bubble in the brake lines. Best to bleed the brakes again. The heat of the pads settling may have boiled a bubble in the brakes (say that 10 times fast).
James
James
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
