Help please re rear window wiper
- Super Exceeded
- Vehicle: 1993 L300S
I am rewiring part of my L300 and i can't figure out what wire is which. There are three wires going into the motor all blue, 1 solid, one with white stripe and one with red stripe, if anyone know which wire is which I would be most greatful. I know one is full time power, one is for the constant on, and one for the intermintant setting, gut which is which?
- Golf Cart
- Vehicle: 1992 Exceed
Re: Help please re rear window wiper
What does the wiring diagram in the downloads say?Super Exceeded wrote:I am rewiring part of my L300 and i can't figure out what wire is which. There are three wires going into the motor all blue, 1 solid, one with white stripe and one with red stripe, if anyone know which wire is which I would be most greatful. I know one is full time power, one is for the constant on, and one for the intermintant setting, gut which is which?
- Super Exceeded
not too sure where to look, hence the post. I did find a schematic on the other delica forum, hard to read but I think I have something to work with.
- Golf Cart
Schematic shows
Blue/Red left
Blue/Black middle
Blue/white right
Double check the solid blue- chances are it has a black line on it.
Look in the L300 section - it shows wiper/washer schematic on its own. The motors should be relatively identical. There will however show a 4th wiree. I think its because they show the front motor. It does have an offshoot (L85) that goes to the rear wiper, so I'm thinking it is the same wiring set up.
Good Luck
Blue/Red left
Blue/Black middle
Blue/white right
Good Luck
- Super Exceeded
SE, if you go to the forum index (upper left of this page is a line that tells you where you are; click >>forum>>). Once in the forum index you will see five headings:Super Exceeded wrote:not too sure where to look, hence the post. I did find a schematic on the other delica forum, hard to read but I think I have something to work with.
- Delica Canada General
Delica Canada Technical
Sightings, Stories & Photos
Purchasing & Importing
Feedback
This is your fundamental key to the site. Everything that we are dealing with right now is in "Delica Canada Technical". If you click on that then it will all be clearer. At the top of the DCT list are three sub-forums:
- Delica FAQ Section
L300 Delica Downloads
L400 Delica Downloads
As you are driving an L300 I would recommend perusing the first two sub-forums in that list.
Coming to a new website can be strange as all the members who have been on this site for a while have become accustomed to figures of speech, &c., it's like learning a new dialect. I make it a point to go to the forum index from time to time, even though it is easier to keep up through "active topics", it keeps me on top of the scene ~ kind of like looking at the map from time to time... smiles.
- Super Exceeded
OK, I gots it done,
Window defoger, works, power lock works, wiper works, Yahoo. I would now like to thank Mitsubishi for using three different wire colours from start to finish. You certainly made my day(s).
Thanks to each of you that offered assistance
Arnold
Arnold
- Golf Cart
I'm glad you can now see where you've been !!!
- Super Exceeded
Golf Cart,
Thanks but you're assuming that my rear view mirror is in place!
