EMERGENCY - NEED Brake Specifications to pass saftey inspect
- Vehicle: none
Can anyone provide brake specifications to pass a safety inspection to register my delica in Saskatchewan. I am sitting at Canadian Tire waiting to pass inspection. Can anyone help?
Re: EMERGENCY - NEED Brake Specifications to pass saftey inspect
from the Russek Manual
Front Disk Brakes
Type: AD
Disc Brake Dia: 258mm
Disc Thickness: 22mm (new) 20.4mm (service limit)
Pad Thickness:10.5mm
pad Material wear limit 1.0mm
Rear Drum
drum Dia: 254mm
Max Dia: 258mm
Min brake shoe thickness: 1.0mm
brake Cylinder Dia: 20.64mm
brake adjustment: Auto
Front Disk Brakes
Type: AD
Rear Drum
drum Dia: 254mm
Max Dia: 258mm
- Vehicle: none
Thank you so much Visotzky. I have been waiting here for almost 4 hours
- EnviroImports.com
also, download the pdf's and print them off , keep them in your glove box for any problems that can come up. they are free to download and you dont have to register or anything.
click here > http://enviroimports.com/technical_downloads.html
Glad to help
- Vehicle: none
Thanks wetcoastnewbie that will be helpful in the future.
