L300 Stretch updates
Re: L300 Stretch updates
Well, it's no Pajero, but it IS beginning to look pretty cool.
- Super Exceeded
- Vehicle: 1993 L300S
Just took her up a couple of Hills in White Rock. Did much better than I expected. I do think my speedo is way out though!!!!fexlboi wrote:Wow, these are 33"? They look quite tiny on your huge lift.![]()
Any experience yet how the van is doing if you push it up a steep hill?
Going from 237/75/15's to 32.5" tires, my egt's shot up from 920 to 1200+ on the same stretch of highway going uphill. Was coming close to cooking the manif and turbo.
What EGT's are you seeing ?
You will be travelling at approx 112km/hr while speedo will read 100km/hr.
My 32's read 110.2km/hr
- Super Exceeded
Well stretch goes back into the shop on Wed, for the side door mod, final paint and yup, looks Like I gotta do it! Solid front axel. I'll go with the Toyota Tacoma front end unless someone knows something I don't (If you do, please let me know). Does anyone know what the gearing in the Delica's front pumpkin is? I'll need to change the Tacoma's mosty likely.
For the under-edumucated, can you elaborate why you "gotta" change out the front end? Just so we can keep up with the rest of the class.Super Exceeded wrote:Well stretch goes back into the shop on Wed, for the side door mod, final paint and yup, looks Like I gotta do it! Solid front axel. I'll go with the Toyota Tacoma front end unless someone knows something I don't (If you do, please let me know). Does anyone know what the gearing in the Delica's front pumpkin is? I'll need to change the Tacoma's mosty likely.
- Super Exceeded
I can't find a way to make the front suspension work so the truck rides like tank. A solid front axel, from everyone I have spoke with, is the only option left.mararmeisto wrote:For the under-edumucated, can you elaborate why you "gotta" change out the front end? Just so we can keep up with the rest of the class.Super Exceeded wrote:Well stretch goes back into the shop on Wed, for the side door mod, final paint and yup, looks Like I gotta do it! Solid front axel. I'll go with the Toyota Tacoma front end unless someone knows something I don't (If you do, please let me know). Does anyone know what the gearing in the Delica's front pumpkin is? I'll need to change the Tacoma's mosty likely.
Under the drivers seat on the carpet there is a little flap. Underneath is the vin/code plate of your L300.
As it's an automatic, 99.9% that you have 4.875 gears in your diffs.
What's the Toyota gears ?
In the rear, you can swap out to 5.29's from most 5-spd L300's or Pajero's. Montero's in the US mostly have 4.26 among other gear sets. If swapping from a Pajero/montero, it will need to be the smaller pumpkin first generation.
- thedjjack
- Vehicle: 1989 L300 HITOP!!
tacoma's are independent front ends aren't they??
You want a 1983 toyota front axle if or a Landcruiser (FJ40, 60, 62, 70 or 80s). Ask on BC4X4 or Pirrate lots of Toyota people on there.
I think the 5 speed has 4.88 gears, I could be wrong. I would pull the gears and count to be sure.
Please post lots of pictures of the swap.
- Vehicle: -
http://www.thisfabtrek.com/land-rover/land-rover.php
http://www.foleysv.com
Just came across these two sites which might be interesting for you...
- Super Exceeded
She's in the paint shop... 10-14 days Yippee
- almac
has the cool side door mod been done yet??
al
al
- Super Exceeded
At the same timealmac wrote:has the cool side door mod been done yet??
Side door mod? What side door mod?Super Exceeded wrote:At the same timealmac wrote:has the cool side door mod been done yet??
- Super Exceeded
I can't say, and Ive asked those that know not to say. But ooooh, it's gunna look cool!mararmeisto wrote:Side door mod? What side door mod?Super Exceeded wrote:At the same timealmac wrote:has the cool side door mod been done yet??
Adam
I'm guessing gullwing door.Super Exceeded wrote:I can't say, and Ive asked those that know not to say. But ooooh, it's gunna look cool!
