Does the Injector Pump not need power to pump? I am pretty sure that the IP is electrical.jfarsang wrote:The L300 2.5 engine does not need electicity to run......
You know what it is, Arnold ~ it's those white windscreen wipers....
GREEN1 WAS NOT WRONG AND HE NEVER ARGUED AND HE KNEW MORE ABOUT TURBOS THAN ANYONE! DON'T YOU REMEMBER ANYTHING! YOU ARE COMPLETELY WRONG WRONG WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!thedjjack wrote:Green1 tended to never be wrong and never backed off, until the day he quit the forum and deleted all his post.
I hope I do not have an electrical problem, I just booked Joshua Tree National Park for after Christmas....Road Trip!
jfarsang wrote:I tried it this morning just to put it to rest.
Start up. Disconnect battery. Drive. Keep driving. Keep driving. No problem. Mechanical engine, injection pump, etc.. reconnect battery. Turn off.
My battery fried two summers ago and took out my alternator in my L300 while in Kamloops driving south. Zero voltage at the alternator and zero at the battery terminals. Both were toast. Luckily, it was still running and I was able to drive it home. Diesel you can fill up with the engine still running so I drove it from Kamloops all the way home with no battery in the battery tray. Drove straight to canadian tire and install a new battery. Then shut it off. Then turned it on and voltage was good everywhere.
Not a fairytale but one with a point.
I don't doubt it'll run with no elec. power. So I'm wondering, though, how does turning the key off cause the engine to stop? I recall there's a wire or 2 connected to the IP. So does that power a fuel shut-off solenoid/valve? If so how does that work? Key on = sol. powered = holding valve open...key off = no power to sol. = valve shut? If so then when you drove with no power had you bypassed this system? Or is it some kind of timed system, such as: default is valve open and key off just starts a timer to power sol. for a short time to close valve? (so no power = no (easy) way to shut off engine?)jfarsang wrote:Start up. Disconnect battery. Drive. Keep driving. Keep driving. No problem. Mechanical engine, injection pump, etc.. reconnect battery. Turn off.
According to:Blackberry wrote: I don't doubt it'll run with no elec. power. So I'm wondering, though, how does turning the key off cause the engine to stop? I recall there's a wire or 2 connected to the IP. So does that power a fuel shut-off solenoid/valve? If so how does that work? Key on = sol. powered = holding valve open...key off = no power to sol. = valve shut? If so then when you drove with no power had you bypassed this system? Or is it some kind of timed system, such as: default is valve open and key off just starts a timer to power sol. for a short time to close valve? (so no power = no (easy) way to shut off engine?)
I assume that you pulled the ground off the battery negative terminal, removing the battery load from the circuit but leaving the vehicle ground intact and the rest of the circuit hot. The alternator output, and all the vehicle systems like ignition are still connected together. Effectively, the vehicle is running off its own generated power - by design.jfarsang wrote:I tried it this morning just to put it to rest.
Ah yer right. I didn't know this about diesels until you pointed it out. Googled for clarity. Neat!thedjjack wrote:Rich, its a diesel so not the "ignition" as a diesel works with compression
