valve settings
rdub
valve settings
Post by rdub »
anyone know the or have the valve setting specs my ticking is getting worse and lasting a long time im a little cocerned thanks
EricN
Vehicle: 90 exceed
Re: valve settings
Post by EricN »
Under the engine cover. Mine says .25mm for both, I believe cold (I did mine cold). I also remember reading about the roller rocker tips failing but I wasn't sure if it was on the L300 or L400. When I did my adjustment (it was way out to lunch on 3, they were too tight), I loosened them all off and checked to make sure the roller tip wasn't all wobbly feeling. Then set the lash.
