Hello everyone, im new to the world of jdm, i just bought a 92 lwb after about a year of looking, i thought i found the rite one for me, it had a good 3 year paper trail of all work done, i bought it off a rcmp officer and it looked like it was well takin car of.....then i bought it and it was all that i had hoped for. 22mpg seats 7 looks cool and has one of the best 4x4 reps out there. well as you might of figgered out ofter 400km at about 105kmph a valve dropped , things got bad fast and i pulled over. had it pulled to a shop i know near home and pulled the head .......its all kinds of bad. not gona evin try to fix it.
so my question is this. has anyone heard about the hundai built 4d56 motor? i found a drop in crate motor with all acc on it inc the fuel pump and starter alt so on for $3200.00 plus 195 to ship it to me. that seem fair? should i get a mitsu made 4d56? does it matter?
i ask because a mitsu 4d56 is rare new and about 5600.00 all dressed up
what do you think?
3200$ sounds about right, and Hyundai is one of the licensees of the Mitsu-stuff (have been for a while) so don't worry about the name. Sounds like the timing belt went just a liiiiittttttle to long - unfortunate, really. Never can really tell with those danged things.
I picked up an l300 with a blown motor, it needs a crank, and number one connecting rod. If the used crank I have here turns out to be no good, I will be going with the hyundia drop in, I have confidence in the workmanship as they didn't redesign the engine, they only reproduced it. This being said, I may have confidence, but I don't have any experience with the hyundia engines "yet", so mine is pure opinion, no facts.
It actually dropped a valve...Not a nice way to go out at 3000rpm under load. I can imagine the damage. Surprise it did not put a connecting rod through the block.
My understanding is there are some minor changes in the motor such as the pre-combustion chambers. If it is a complete motor with injector pump and turbo. You should be able to sell the turbo and injector pump ect... to get a few $$ back.
Hyundai has applied 4D56 engine to numerous models.
porter truck, grace, galloper, libero, starex.
When you buy a Hyundai 4D56 engine, you need to figure out what model the engine is used for.
If you get a different application, you may need more modification/money or have another problem.
Mitsubishi does not make complete engine anymore, but Hyundai Mobis still supplies them fortunately.
Before you buy a complete new engine, you need to know what problem your engine has.
Most likely, it needs only head work or some crankshaft/pulley,,,,.
We have all kinds of engine parts for 4D56, and all are from Hyundai original.
Steven
Rising Sun Auto Import Inc. **Ultimate Home of Delica in North America**
Delica Injection Pump Rebuilt, Cold Start & Engine/Turbo Work Specialist Unlimited source for new & used parts
hyundai engine are almost same quality as mitsu engine, if you are getting all new pump injector, timing belts etc, better to go with a new one rather than fixining. initially you will spend a bit more but in the long run it will be beneficial considering you are keeping the pajero for a while.
dbaba wrote:hyundai engine are almost same quality as mitsu engine, if you are getting all new pump injector, timing belts etc, better to go with a new one rather than fixining. initially you will spend a bit more but in the long run it will be beneficial considering you are keeping the pajero for a while.
X2.
yeh the ip is good, looks like a new seal kit was done last fall. it will be up for grabs. but ill wait till everything is running good first.
thanks for the info in the hundai motor im gona go with that as my choice, think it will cost less in the long run. im gona have it shipped on wed. should get here on friday.
shop thinks if all works as planed it will be on the road by next weekend oh ill have a starter, ip, used turbo and injectors up for grabs. kinda thinking about getting the injectors re-done as a spair set, if anyone needs something just msg me ill see if i can he lp
92Nicopolis wrote: a valve dropped , things got bad fast and i pulled over. had it pulled to a shop i know near home and pulled the head .......its all kinds of bad. not gona evin try to fix it.
what do you think?
Sorry to hear that! How many clicks on it now? Can you post pictures? I would ask for second independent opinion from trusted mechanic and leaning to fix it rather than spend 5600 for new engine...or you can add a bit and get new truck and sell all you can rip off your old one...
[Sorry to hear that! How many clicks on it now? Can you post pictures? I would ask for second independent opinion from trusted mechanic and leaning to fix it rather than spend 5600 for new engine...or you can add a bit and get new truck and sell all you can rip off your old one...
Good luck,[/quote]
It has 1526??km on it, as far as a 2nd guy to look at it, theres no need. i saw for myself the block and head are toast, In the short time i drove it i fell in love with it. i was thinking of getting a 2nd one from calgary only $3000 but tranny is going on it, id use the motor from it, but still new is better and if the tranny is gone then how hard of a life has it had?
oh well the new hundai motor will de orderd on tuesday, and ill have the kind of truck i thought i was buying. as far as pics go i dont have any at all but ill see what i can do
the shop is pretty good about that kind of stuff.
Ok, So i just emailed the guy to order the new motor. im gona go with a new inj pump and injectors, just to save on labour cost. but everything else is in good shape on the old one. so ill use the old stuff (try to save some $) i was hoping to have this all done last weak but my cash flow was kinda low. but thats all takin care of now. So ill order it when i hear back from Maximum in Richmond. Oh anyone have any good or bad things to say about them?
yeh.. so i was gona order it today but now im kinda in a hard spot now so im gona sell it
after talking it over with the shop they have me thinking its not worth it to put in a new motor, and all the conflicting info between the two motor suppliers (maximum and rizing sun) has really pissed me off. More rizing sun than anything. if they were trying to scare me away from the compitition they failed but scared me away all together..I have decided that i cant risk spending another 5-6 k and have it break on me. As this would not be cash on hand but a loan on a 19 year old suv. So anyone want to take it off my hands? make me a offer and ill see wat i can do. thanks
Have you talked to CVI as well? They have often rebuilt engines in different grades available too. Might be even worth to just give them a call and asked the same questions you had to Rising and MaxO.
