leaking oil pressure sensor....
madmazda
Vehicle: 1994 l400
Post by madmazda »
well under the hood and noticed a bit of oil leaking from the oil psi sensor on the front of the engine..... where can one get one of these or stop it from leaking.... I gave it a bit of a wiggle and seems tight..... any comments are appreciated gang.... 8-) :M :M
Re: leaking oil pressure sensor....
The JDM dealers have them.
It's not L400-specific. You can get it locally. Just need to match up the part# on it. Someone posted it last year in the L400 tech section.
madmazda
Vehicle: 1994 l400
Post by madmazda »
ok cool..... Jesse what the hell would we do without you..... :-D I'll try to find some sort of number or email a dealer Thanks again.... 8-)
Fishtank
Post by Fishtank »
Where is it leaking from? If it's just the threads you may be able to get away with a few wraps of teflon tape.
you'd continue being you !
I was a delica-noob not long ago and just took my mech skills + my google'ing skills and ended up with a good start. This forum was bustlin' a few years ago when things delica-esque were fresh.
There will always be a person more knowledgeable in a specific are than you and a person less knowledgeable. My living ethic is to learn from the first and pass onto the latter educating myself in the process. Good flow of info works well that way.
Profister
Post by Profister »
Return to “L400 Technical”
