oil filter part number
bassnailer
I did a search and came up with this part number: Napa oil filter part number: NAPA 1067 or WIX 51067
I know that there are two different sizes of oil filter out there. I want the bigger of the filters (which I believe is stock). Are these the right numbers? I want to change my oil tomorrow.
- Luna-Sea
Re: oil filter part number
Also a Baldwin BD28
Right On!
Right On!
or Fram PH6355
bassnailer
Thanks!
bassnailer
is the filter easy to reach from under the van, or is it easier to access from the inside?
From the undercarriage.
- MardyDelica
bassnailer=
i have oil filter in stock made in japan for L300
pls just call me anytime cheers;\
mardy
mardy
- Rising Sun Auto Import
As far as I understand, commercial ads have been resricted in delica forum. When you need some parts, search wiki or delica trader. If you need special products that are hard to find, you may get replies from other members. Just my thought. I maybe wrong.MardyDelica wrote:bassnailer=
i have oil filter in stock made in japan for L300 and l400
pls just call em anytime cheers;\
mardy
Steven
- MardyDelica
steven,
i am not selling my stup he buy his vehicle from me.
just want to help him for this oil filter as the fram and napa oil filter is more expensive to buy than my filter.
this is just a help for him.
as you can see i dont put any price on it
cheers;
mardy
cheers;
mardy
MardyDelica wrote:steven,
cheers;
mardy
Hi Mardy,
I understand, but you'd better use a PM in that case as it is intended from forum's newly set up commercial ads policy.
Steven
Thank you both for keeping the site rules in mind. A pm would be preferable.
In regards to the Fram filter, it's my understanding that the oil doesn't have to be changed quite as frequently if you are using one!?
- konadog
- Vehicle: 1992 GLX L-300
Nix... Fram is just an oil filter and needs to be changed as often as the Mitsu or Sakara or Baldwin and the rest.nxski wrote: In regards to the Fram filter, it's my understanding that the oil doesn't have to be changed quite as frequently if you are using one!?
Good thing I opted for the amsoil dual bypass then!konadog wrote:Nix... Fram is just an oil filter and needs to be changed as often as the Mitsu or Sakara or Baldwin and the rest.nxski wrote: In regards to the Fram filter, it's my understanding that the oil doesn't have to be changed quite as frequently if you are using one!?
- thedjjack
- Vehicle: 1989 L300 HITOP!!
I have seen some test on FRAM and ever since I have stayed far far away
Jordan
- Vehicle: 89 low roof L300
Not delica specific but this is a good look inside different filter brands: http://minimopar.knizefamily.net/oilfil ... rence.html
