Third trip out on vegetable oil ... took the van to Sun Peaks for a day of cross country skiing!
Wanted to see how the diesel engine started after being left cold in the parking lot for a couple of hours.
No problems starting ... barely cranked the starter motor and it fired right up (it was only -3C though). I noticed that if the battery is not fully charged the van does not start well in cold weather, so I have been careful to make sure I do not run the battery down with the engine off.
Installed the hitch that the company Maximum Overdrive sells for the L400. Only problem installing it was working around the WVO fuel tank. Would have been much better off installing the hitch first and the tank second. The fuel filler fitting on my tank (centred on the side of the tank) interferes with the support tab of the hitch that rests on the frame under the van. I had to grind the bushing going into the tank to get everything to fit ... there is enough clearance now but it was a real squeaker. I would offset the filler fitting towards the front of the tank to avoid any problems if I were doing this again.
Have now finished my first tank of WVO ... will need to filter another batch!
