unless you go front and rear lockers, without a doubt a locker in the rear/open front is the best combo.
it's physics. most times when you 'think' you need a front locker is to pull uphill. In this case, if the rear is locked, most of the weight is on the rear wheels pushing uphill that give it most traction. I learned it during a wheeling course a long time ago and it is the consensus among general wheelers.
Locking the front puts an extreme amount of stress on the front axle which is inherantly weaker then the rear axle, ie. smaller R&P, smaller shafts, axle CV-joints, and hubs. All these things become factors with the increased work the frontend must do to make up for the lack of traction in the rear compounded when you are turning.
I had an XJ locked front and rear for 11 years and only used the front locker 3 times and even then I could have taken a different line with only the rear locked.
The money on a front locker is much better spent either locking the rear or putting into better gearing/tires,recovery gear,etc..
With that said, it would be nice to see a lifted L400 locked front and rear on the trails.
