grease points on delica ????
- Mr. Flibble
Re: grease points on delica ????
Has anyone found the grease nipple size other than "metric"?
I need to order my gun online, but I don't know the size.
- Vehicle: 94 L400 SuperExceed
Did you find out the size?
- Mr. Flibble
No, I still don't know.stever1000 wrote:Did you find out the size?
- macro
- Vehicle: L400 "The Invader"
Why do you need to know the size? Isn't there only 3 grease points on the L400? All accessible with a grease gun?
-Mat
@delicacanada on Instagram
- Mr. Flibble
I need to know the size of grease fitting to order so I get one that fits.macro wrote:Why do you need to know the size? Isn't there only 3 grease points on the L400? All accessible with a grease gun?
There are a few more than 3, depending on a few factors:
http://www.mdocuk.co.uk/forums/viewtopi ... 8bfe9141f0
- macro
Ahh I see, so yours currently has the bolts? The only ones mine has are on the driveshaft.
-Mat
I greased mine today and I had at least 6
- macro
Where were the others??
-Mat
2 on the tie rod ends, at least two total (maybe 3? I can't remember) on the front and rear drive shafts, and 2 on my upper ball joints (I had to remove the grease nipple from one of my tie rod ends to use on the ball joint [removing the small bolt from the ball joints])
Have you guys thought about checking the shop manual? Then you will know for certain.macro wrote:Where were the others??
- macro
Believe it or not, yes.FalcoColumbarius wrote:Have you guys thought about checking the shop manual? Then you will know for certain.macro wrote:Where were the others??
-Mat
