Identify this mystery box and connector
Fishtank
Post by Fishtank »
Hey guys,
I was cleaning my van and removing several meters of wiring and multiple electronics items that the previous Japanese owner graciously installed, when I came across this box and connector under the drivers seat. Can anyone tell me what it is and if this connector needs to be plugged in somewhere?
PS this is looking fwd from the back seat floor.
after oil
Re: Identify this mystery box and connector
Post by after oil »
remote lock is my guess
luckydad
Vehicle: 95 L400 Royal Exceed Yamaha Scooter
Post by luckydad »
Under the driver seat of my van is an amp for the sound system. Useless I think when you remove the stereo.
Phil :-)
Mr. Pistachio
Vehicle: L400 LWB Super Exceed
Post by Mr. Pistachio »
It's a warp device. Use with extreme caution!
TardisDeli
Post by TardisDeli »
Agree with After Oil. Jay says its remote door lock, he has seen this on several delii. Probably they were factory installed (judging by the plugs). None of them work now (they all appear to have not been used for some years) and NO you will NOT find a remote here that works on them. Christine.
after oil
Post by after oil »
mine works, and a few have passed my hands that work
Fishtank
Post by Fishtank »
after oil wrote:remote lock is my guess
TardisDeli wrote:Agree with After Oil. Jay says its remote door lock, he has seen this on several delii. Probably they were factory installed (judging by the plugs). None of them work now (they all appear to have not been used for some years) and NO you will NOT find a remote here that works on them. Christine.
Okay, now how can that be when it's been identified in Artacoma's thread here http://www.delica.ca/forum/another-myst ... 11073.html and his is "attached to the inside of the driver side rear panel next to the speaker"? :?:
This seems like a trend, when someone posts a picture of an unknown electrical box, the default answer is a keyless entry controller? :shock: :-D
after oil
Post by after oil »
the antenna plug gives it away: they're both keyless remotes. i know for sure that my keyless remote receiver is under the seat. and the antenna goes up the pillar behind the door and over the door in the door seal.. although i have an L300
Fishtank
Post by Fishtank »
I can't seem to see the antenna plug you're talking about any where in the picture above...?
after oil
Post by after oil »
okay, so the photo in the other thread has the antenna plug. i was guessing that your is remote lock too, because thats where mine is, in my L300..
psilosin
Vehicle: L400
Post by psilosin »
Are there any metal cooling fins on it? Similar to one of teh posters above that is where my factory stereo amplifier is located on my L400. If you have an aftermarket stereo it would be disconnected and not doing anything.
