Power Assist Options?
- username
- Vehicle: 1991 super exceed
I'd really like to know if anyone has figured a good way to help delicas climb hills. It's pretty much my only complaint with the vechicle... slowing to 50 or 60 on the steep inclines.. I've heard rumors of propane injection, whaddabout nitrous? majikal fuel additives?
- K-Factor
- Vehicle: LN106 Hilux, JD81Cruiser
Re: Power Assist Options?
I just posted a little speil on this on the above post, but try this,
http://www.snowperformance.net/products.php?p_cat=259
Water/methanol injection
Very reasonable price, and low input costs.
KSY
KSY
Gear down.username wrote:I'd really like to know if anyone has figured a good way to help delicas climb hills. It's pretty much my only complaint with the vechicle... slowing to 50 or 60 on the steep inclines.. I've heard rumors of propane injection, whaddabout nitrous? majikal fuel additives?
different engine or move to flat ground....seriously
- after oil
set your timing, increase your boost pressure, clean your injectors. replace your air filter, check your egr, check your turbo...
after oil wrote:set your timing, increase your boost pressure, clean your injectors. replace your air filter, check your egr, check your turbo...
I agree with above....then, different engine or move to flat ground....seriously
Like Mararmeisto says: Gear down. She's a Delica, not a Ferrari. She drives like a truck, not a spyder.
- username
different engine eh? wonder if I could get a l400 engine in my l300.
measured and it ain't lookin' pretty.username wrote:different engine eh? wonder if I could get a l400 engine in my l300.
Would have to cut, re-brace, weld the bulkhead/floor/frame and sacrifice some interior room.
Both the engine and transmission are a lot taller - longer than the 4D56T/trans.
With that said, anything is possible. All relative to the size of your wallet.
Some people here have over $20k into a relatively stock L300. You can easily get a $6k nice shape L300, even less if the engine is shot, and spend $14k to have a professional shop transplant an engine of your choice and while they are at it a SAS.
- username
jfarsang wrote:measured and it ain't lookin' pretty.username wrote:different engine eh? wonder if I could get a l400 engine in my l300.
do you know of another engine that is a better fit jfarsang?
Paule
- Vehicle: 1997 L300 Active World
I hear there's a gasoline engine that fits pretty well....
If I had an L300 with a blown engine, instead of forking out $3-4k for another underpowered 4D56T with a soft head that likes to crack under pressure, I would just buy a 1/2 cut from Japan and drop it in.
Same engine but a lot better and newer.
http://kotse.com/home/index.php?option= ... Itemid=197
Power - 131 kW (178 PS) at 4,000 rpm (our L300 engine (67 kW) at 4,200 rpm)
Torque - 350 N·m (258 lb·ft) at 1,800 rpm
Engine type - Inline 4-cylinder
Fuel system - 2nd Generation Common Rail Direct Injection (CRDi)
Compression ratio - 16.5:1[13]
That would make an L300 not only fly with more than twice the power output but be more fuel efficient and fun to drive at little expense for modification. You would just need the engine, accessories, ECU, computer, harness and bell housing.
powered by a 2.5 liter 4 in-line DOHC 16 valve with Variable Geometry Turbocharger and Intercooler 4D56 diesel engine. Thanks to the VGT technology, the Montero Sport’s Common Rail Diesel engine now pumps out 176 horsepower and 350 Nm of torque. The Variable Geometry technology reduces turbo lag time and increases overall efficiency across the entire RPM range. Aside from being powerful, durable and dependable, this engine has been noted to be, responsive and economical.
4D56T Intercooled Turbo 3rd Generation DI-D with variable geometry turbothe new 2.5 liter 4D56 Mitsubishi Direct Injection Diesel with Hyper Common Rail DOHC 16-valve Turbo Intercooled engine. Maximum power output from this 2.5 liter engine is at 136PS @ 3,500 rpm and maximum torque is 314 N-m @ 2,000 rpm. The adoption of the DI-D Common Rail system enables the 4x2 Strada to deliver high output, flatter torque curve, low fuel consumption, clean emissions, and quiet operation. This new Direct Injection Diesel Common Rail engine is already Euro-2 compliant and is properly matched with the current diesel fuel in the Philippines.
- username
wow, that sounds good. way better than the 26.5hp on the stock delicas!
you realty think that could be done for less than 3-4000$? seems everyone would be getting it done if that was the case. a bit more power and better fuel efficiency would make these awesome old vans so much better.
No. 3-4k would be the cost of the engine/etc. You'd still need a shop to drop it in or DIY. I prefer the DIY method.
- shealy
- Vehicle: 92 Delica Exceed
Wow. That would be awesome! Has anyone ever done this swap? I know SuperExceeded is popping a different engine in, but has anyone ever put an engine like this or another in a stock(ish) L300?
