1. Clutch master cylinder
2. Clutch slave cylinder
3. Brake wheel cylinder ( LH, RH )
4. Steering rack boot
5. CV joint boot_inner
6. CV joint boot_outer
7. Radiator hoses
8. Inner tie rod end
9. Front stabilizer link
10. Rear stabilizer link
11. Idler arm, complete
12. Upper ball joint
13. Lower ball joint
14. Outer tie rod end
15. L400 center console tray
16. L400 ACC box
17. Spacer_rr diff pinion bearing
18. Rr diff case bearing
19. Rr diff drive pinion oil seal
20. Rr diff drive pinion front side bearing
21. Rr diff drive pinion rear side bearing
22. Front diff drive pinion oil seal
23. Fr diff drive pinion, rear bearing
24. Fr diff drive pinion, front bearing
25. Fr differential side bearing
26. Fr diff side oil seal
27. Coolant expansion bottle
28. Crankshaft pulley
29. All radiators
30. Rocker cover gasket, front/rear rubber packing( camshaft end seal )
31. Head gasket, complete gasket set
32. Rotors, front and rear
33. Water pump
34. Rocker cover bolt seal
35. Oil seal rear separator, case, case gasket
36. Rear main seal
37. Flywheel assy
http://www.delica.ca/forum/l400-new-par ... 10298.html
We do all kind of repair service for L300, L400 and Pajero with over 500 parts in stock and licensed diesel mechanic on duty.
All part purchase inquiry, pls send email to japancarexpress@gmail.com or call Steven 778-995-2459.
All repair/service inquiry, call for appointment at 604-544-5120/778-995-2459 or email to japancarexpress@gmail.com.
Monday to Saturday ( 10am - 6pm )
Steven
