Rising Sun Auto Import has finally stocked lots of Suspension/Steering /Brake /Axle/Differential Parts for your maintenance needs.
( L300 starwagon )
1. Inner tie rod
2. Outer tie rod
3. Steering rack boot
4. CV joint boots ( inner & outer )
5. Rear swaybar link end
6. Upper ball joint
7. Lower ball joint ( LH, RH )
8. Front stabilizer link kit
9. Front & rear shock
10. Front rotor
11. Front brake pads
12. Front caliper
13. Axle hub bearings/ oil seal
14. Various oil seals & bearings for Differential
15. Manual locking hub
16. Various bushings
( L400 delica spacegear)
1. Front stabilizer link
2. Rear stabilizer link
3. Upper ball joint
4. Inner tie rod
5. Outer tie rod
6. Lower ball joint ( LH, RH )
7. Steering rack boot
8. CV joint boots ( inner & outer )
9. Front & rear rotor
10. Front & rear brake pads
11. Front & rear caliper
12. Axle hub bearings/oil seal
13. Various oil seals & bearings for Differential
14. Manual locking hub
15. Various bushings
( pajero )
1. Inner tie rod
2. Outer tie rod
3. Upper ball joint ( LH, RH )
4. Lower ball joint ( LH, RH )
5. Steering rack boot
6. CV joint boots ( inner & outer )
7. Idler arm complete
8. Pitman arm
9. Front stabilizer link
10. Rear stabilizer link
11. Front & rear rotor
12. Front & rear brake pads
13. Front & rear caliper
14. Axle hub bearing/oil seal
15. Various oil seals & bearings for Differential
16. Manual locking hub
17. Various bushings
For all part inquiry, pls email to japancarexpress@gmail.com
Steven 778-995-2459, 604-544-5120
We have over 500 parts in stock for your Delica maintenance and repair.
Also we are running a Delica repair facility with licensed diesel mechanics on site.
List of Suspension/Steering /Brake /Axle/Differential Parts
- Rising Sun Auto Import
madmazda
- Vehicle: 1994 l400
Re: List of Suspension/Steering /Brake /Axle/Differential Pa
do you have the vibration damper for the l400 auto tranny the square bloce that attaches right at the rear of transmission ???? if so how much just P/M me with the results... Cheers...
