One rim got loose somehow last winter and I ended up slightly damaging the inside of the lug holes (is that the right term? where the bolts come thru...)
Anywho, the mechanic who helped me out said I shouldn't use the rim how it is, that I should either replace them all or find someone who can fix the damage.
Since I've got 3 other rims in perfect shape, and since the toyota rims look real good on the Deli, I'd like to see if it can be repaired.
Anyone in Cowtown know where I might take this rim for machining?
Nate
