Hi Everyone,
I'm new here. I just bought a 1991 Pajero (MKII). So far so good... I'm really enjoying it.
Anyhow, I need some rims for a set of winter tires. Does anyone have a set they are willing to sell?
What other rims can I use for this?
Am I correct that only L400 rims will fit it... I found this information floating around.
Mitsubishi L300 Delica center bore hub = 106mm
Mitsubishi Montero/Pajero Gen I = 106mm
Mitsubishi L400 Spacegear center bore hub = 108mm
Mitsubishi Montero/Pajero Gen II = 108mm
Pajero rims
Moderators: delicanuck, mark
- littlepaj
- Vehicle: 1991 Pajero
- littlepaj
Pajero rims
Hi. I need some rims for my 1991 2nd gen Pajero for snow tires.
Does anyone have a set of rims they want to sell me?
- Vehicle: 1992 Delica L300
Re: Pajero rims
Sure!
But I'm in Ft. McMurray, AB. Just took the old set off am trying to figure out what to do with them now. They work, but could use a little TLC to spiff 'em up...
- Raule Duke
- Vehicle: 92 Pajero SWB
Re: Need Rims for my Pajero
I Can't say for the Gen 1/L300's but you are rite that your truck has a 108mm Center
almost all Toyota truck rims will fit so you should do all rite looking in a scrap yard or on C list!!
(for sure all the Tacoma Pickups and 4Runners will fit but "some" of the Tundras have 110mm center)
"There's a uh, big machine in the sky, some kind of, I dunno, electric snake, coming straight at us!"
Re: Pajero rims
Chevy, Nissan and Toyota rims with 6x5.5 bolts pattern and 4" of backspacing
Just be sure measure the hub center bore. It's 108mm
- littlepaj
Re: Pajero rims
Hey!
Thanks for the tips.
Jfarsange, what do you mean by "4" of backspacing"?
And... Jfarsang... I found the post where you wrote "What I did not realize at the time was that most Toyota trucks have a 106mm center bore hub diameter"
...But Raule Duke says almost all Toyota rims will work!
So... who do I believe!?
Sorry! I don't know anything about wheels. Thanks for the help guys!
- littlepaj
Re: Pajero rims
I found this site: http://wheelsupport.com/toyota-bolt-patterns/
It looks like Tacoma/4runner wheels have 106mm centre bore.
Raule Duke, do you have any experience mounting these on a Pajero? Are there some 4runners with a 108mm bore?
Re: Pajero rims
Most toyota wheels have a center bore diameter of 106mm
Mitsubishi 2nd gen Pajero/L400's have a center bore diameter of 108mm
meaning if you buy a toyota wheel that has a 106mm center, you will need to bore it out/grind an extra 2mm to allow it to fit onto the Mitsubishi 108mm hub.
with that said, I have yet to see an aftermarket toyota wheel under 108mm center (perfect for Pajero/L400)
