L400 alignment specs
monnomania
Vehicle: 96 L400 lwb clr
Post by monnomania »
Anyone got the 'actual' alignment specs for a L400.
There are several floating around - including a pdf of an alignment report. Delica UK has at least two for a L400 (NOT the same) and there are others for presumably an L300 - but not clearly labeled as such.
Our friends at CC Autos indicate that there is sufficient difference with a Montero that the L400 cannot use the Montero specs.
I am looking for the 'final answer'... Anyone?
supa_fox
Vehicle: Delica L400 LWB
Re: L400 alignment specs
Post by supa_fox »
Hey There
Check in
http://www.delica.ca/forum/the-1995-l40 ... -9266.html
under steering, I just had mine aligned to those specs and it seems to work pretty good, pulls a bit to the right still, but they said they couldnt quite get it perfect.
nxski
Post by nxski »
I had mine aligned twice at Cvi, had my wheels balanced 3 times, replaced all the components that could be responsible (don't remember the names, also done at CVI) and it still pulls right. This is partially to do with my roof box configuration but as it got worse after replacing my steering wheel I think there may be an issue there as well. The alignment should be done with a laser to match the rear wheels. I don't see why specs are needed!?
monnomania
Thanks Supa-fox! I looked far and wide and only needed to look under my feet. Bummer.
well done.
Chris
ps keep an eye out on the spring thread...I have some interesting results...
